110 Users Online (109 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Curtain panel - ''wont make type'' - Please help
Tue, Apr 23, 2013 at 2:38:14 AM | Curtain panel - ''wont make type'' - Please help
mickc55
3 Stars: 2 Votes
Hi guys,
Im really stuck! We have a client presentation tomorrow and we need to find a solution.
The problem: The fasade we have - see image 'fasade' - has a non rectangular panel at the top.
Revit can create only system panels if they geometry is non rectangular.
This is our panel: see image 'panel' It has 3 layers and it wont fit into the off shape panel.
Could I please get some input as to how to solve this problem??
Bes regards,
Michael in Oslo
Be brilliant,
Michael
Tue, Apr 23, 2013 at 7:15:46 AM | Curtain panel - ''wont make type'' - Please help
3.5 Stars: 395 Votes
There is probably no way to do this.  Some things are better done as materials.
Tue, Apr 23, 2013 at 7:22:01 AM | Curtain panel - ''wont make type'' - Please help
mickc55
3 Stars: 2 Votes
Hi WWHub,
Materials, can you explain what you mean by this in a practical sense?
Best,
Michael
Be brilliant,
Michael
Tue, Apr 23, 2013 at 7:48:31 AM | Curtain panel - ''wont make type'' - Please help
You don't really explain what you have or why you used a CW to create it.
  • You exterior striped surface could / should be a material.
  • Why model all 3 layers?  Sometimes you are better off to model simple and detail what is not modeled.
  • Maybe this would be better off as a wall type, then have your CW battens only in the same place - with empty system panels.  The wall can then be sketched.  I understand that this may ne be right in plan but you can handle that differently.
Tue, Apr 23, 2013 at 8:10:58 AM | Curtain panel - ''wont make type'' - Please help
mickc55
3 Stars: 2 Votes
Very good,
I get what you mean now, Il give it a shot and post the results.
Thanks WWHub!
Be brilliant,
Michael
Can't find ''Rectangle Panel - MPK''
Thu, Apr 3, 2014 at 5:50:24 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Can't Make Type - curtain wall panel on imported rhino mass
Mon, Sep 27, 2010 at 8:02:47 AM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
Page generation time: 2.0231
