89 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> assembly
Mon, Apr 22, 2013 at 5:03:47 AM | assembly
ronmalit
5 Stars: 3 Votes
i watched an autodesk video, they mentioned that the assembly feature is added with PRECAST in mind.
i have been trying to do this. i have 2 different rvt files let say housing blk 1 and blk 2.
-i edited blk 1 and created an assembly AA (column and rebar)
- i opened blk 2 and pasted the same assemlby AA.
-if there is a change in assembly AA, i will open and edit blk 1 and update assembly AA.
QUESTION:
what is the correct way to update assembly AA in blk 2? is there any semi-auto update method?
if i will just paste the updated assembly AA, it will create new assembly AA2
i can not:  edit blk 2, delete the affected assembly, paste the updated assembly and position one by one again (speaking of a large scale project).
i can not: edit blk 2, update the assembly AA manually. there will be a chance that assembly AA in blk 2 will not tally with blk 1, blk 3, blk 4, etc.
** dont be mad, i dont have much... i am homeless
Modifying vertical structure in edit assembly
Fri, Feb 9, 2018 at 4:27:21 PM
Uniformat assembly codes
Thu, Jan 31, 2013 at 11:21:12 AM
Existing wall assembly visable in New Construction phase
Wed, Nov 2, 2011 at 5:49:10 PM
Editing of Assembly
Thu, Feb 14, 2013 at 2:20:45 PM
Tagging objects within an assembly?
Tue, Jan 3, 2012 at 3:08:48 PM
Page generation time: 0.3690
