31 Users Online (28 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> How to apply materials to trusses?
Sun, Apr 21, 2013 at 5:13:00 PM | How to apply materials to trusses?
mrjackietu
Hi,
I am wondering how you could apply material to the trusses after you loaded the family? There isn't an option for the material under "Edit Type" so I am stuck to it's original material. If you know how to, please let me know!
Jackie
Mon, Apr 22, 2013 at 3:42:47 AM | How to apply materials to trusses?
4 Stars: 203 Votes
Double check please, you must have a mat. parameter in "Instance or Type"
Mon, Apr 22, 2013 at 7:37:16 AM | How to apply materials to trusses?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You have to actually ADD a material parameter to the extrustions in the family then you will get an option in your project to change the material.
Mon, Apr 22, 2013 at 11:27:30 AM | How to apply materials to trusses?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
1. Open the family
2. Create a new instance parameter called 'Truss material' and set it to type 'Material'.
3. Click on the truss geometery (each part).
4. On the properties palette find the Material field and click the little tiny button on the right hand side of the editable field.
5. Set it to the parameter from step 2.
6. Save
7. Load to project
8. Over write
9. Click on truss and click the Truss Material parameter you made and set it to the material of choice.
I think should do it.
Edited on: Mon, Apr 22, 2013 at 11:30:19 AM
Tue, Apr 1, 2014 at 6:03:57 PM | How to apply materials to trusses?
Josephrb
Maybe my response is a little too late; but it might just help someone.  You can apply materials to separate members without having to edit the family.
1. hover over the member in a 3d, elevation or section view
2. Press tab, you should be able to select a single element.
3. Edit its material properties.
I hope this saves someone's time!
Apply Revit materials to Sketchup import [ 1 2 3 ]
Fri, Oct 14, 2016 at 12:52:20 PM
43
Invisible Structural Trusses
Fri, Nov 8, 2013 at 3:00:12 PM
how to apply flooring materials
Sat, Sep 2, 2006 at 2:49:35 PM
MATERIALS - apply image is populating other materials
Fri, Apr 25, 2014 at 9:55:13 AM
Generic Model (How to Paint or apply materials)
Wed, Oct 9, 2013 at 12:09:41 PM
Page generation time: 2.2366
