68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Missing MEP Library
Fri, Apr 19, 2013 at 1:16:36 PM | Missing MEP Library
JRoge
We have 3 installations of Revit MEP 2013 in our office.  The most recent installation is missing the MEP families.  Perhaps it was an option that was not checked when it was installed...I don't know.  What is the best way to load those families?  Can they be copied from the other computers?  I assume it's more of a process than just straight copying.  Is there a better way to install them?
Thanks in advance,
John
Fri, Apr 19, 2013 at 2:43:03 PM | Missing MEP Library
Are you really installing the library on every system?  We keep that on the network where it can be controlled.
Fri, Apr 19, 2013 at 3:09:27 PM | Missing MEP Library
JRoge
for now, yeah, we're installing on each machine.  We're just getting to the point where we may want to put in on the network.  Is that just a matter of copying the library files to a network drive and configuring each machine to look there for it?
Fri, Apr 19, 2013 at 3:17:52 PM | Missing MEP Library
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Just copy over the Library Folder and point to it in the REVIT options. Better to put it on the network and point to it there however and no more difficult. Probably easier in fact.
Fri, Apr 19, 2013 at 4:10:44 PM | Missing MEP Library
JRoge
Putting the libraries on the network did the trick!  Thanks from a newbie.
2012 mep material library
Sun, Nov 27, 2011 at 3:24:24 AM
Missing Revit Library??
Mon, Feb 11, 2013 at 9:35:05 AM
Revit 2009 Web Library
Wed, May 21, 2008 at 4:13:54 PM
Missing library in Revit 2013
Mon, Apr 30, 2012 at 7:57:19 AM
RPC render images missing
Wed, Nov 24, 2021 at 11:45:43 AM
Page generation time: 0.6572
