69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit 2013 - Sloping site & retaining walls
Thu, Apr 18, 2013 at 3:22:37 PM | Revit 2013 - Sloping site & retaining walls
joeinck
Gretings,
What is the best way to handle the contuors and required retaining walls on a sloping site?
I am sloping 2', need to cut out the ground for my doors. I thought building pad, but not working, started adding points to my surfaces but that is crazy work. I have not yet merged my surfaces....
thanks
j
Thu, Apr 18, 2013 at 3:29:13 PM | Revit 2013 - Sloping site & retaining walls
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What do you mean its crazy?  See the attached images. I did that in about 5 minutes. No need for a building pad, you'd put the points like the would be in real life.
Thu, Apr 18, 2013 at 3:40:51 PM | Revit 2013 - Sloping site & retaining walls
As teafoe says ... just add a point to both sides of your wall.  Then more in the field as required.
Fri, Apr 19, 2013 at 10:21:06 AM | Revit 2013 - Sloping site & retaining walls
joeinck
Guess I am not doing something correctly.  When I add points to a Topo surface, they are essentiall ignored and the topo simply connects 4 points, ignoring anything more complicated than a rectangle.  My grading goes all around my building (not a single slope) and no mater what I draw it will just connect 4 points. So I have been drawing a bunch of rectangles and thats the 'crazy' part I mentioned earlier.
my topo is simple, rectangle at 100, 101, 102, 103. have 4 walls up 8' and a floor, all with a base at 100.  cut a section and the topo goes right through the building...
Building pad is no good, as it also hides the interior of the building while in Section view (and leaves a line at the top of the pad).
Just want to have my building sit 2' down from the top of a hill that slopes away in all directions.
Also, I can not label the contours, draw my sketch line perpendicular to the contour (which I am assuming is the line generated by creating a Topo surface) and I get the 'does not intersect a contour' message.
fun times
j
Fri, Apr 19, 2013 at 2:55:41 PM | Revit 2013 - Sloping site & retaining walls
joeinck
Hey Ho, I got it to GO....
I had to make four seperate slopes.  You can not think of a site like a 'Wedding Cake' bs 'stack' topology.
thanks
j
Retaining walls on site
Tue, Apr 15, 2008 at 6:02:55 AM
boulder retaining walls on a steep site
Wed, Sep 26, 2012 at 8:15:06 AM
REVIT 2013 Sloping Pipe System Tutorial
Wed, Jan 2, 2013 at 9:37:27 AM
Buillding Road and Retaining Wall in Revit
Tue, Apr 30, 2013 at 7:28:22 AM
Multiple units on sloping site
Tue, Feb 21, 2006 at 3:29:30 PM
Page generation time: 2.1322
