39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Elevation level change
Thu, Apr 18, 2013 at 2:23:48 PM | Elevation level change
Warchitect
4 Stars: 5 Votes
So I have this multi building project. The image is of the garage-inlaw unit. The elevations are set to project zero of the main house, because there is one topographic surface...
THe planning department doesnt like it because they dont want to do the math to work out the heights of the levels.
is there a way I can assign new level heights to the bullets (in a sense making a new project zero for just this part of the project) without making the model update with new levels which would tear the model apart...
does that make sense?
Thu, Apr 18, 2013 at 2:29:10 PM | Elevation level change
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Search Relocate Project in your help
Thu, Apr 18, 2013 at 3:06:42 PM | Elevation level change
Warchitect
4 Stars: 5 Votes
Thank you very much. perfect!!! didnt realize you could relocate vertical. shoulda though of it.
Level height change
Wed, Sep 28, 2011 at 2:10:58 PM
How to move a single level datum without moving anything in model
Tue, Sep 29, 2015 at 1:53:58 PM
Change Base Elevation
Mon, Oct 6, 2014 at 12:11:08 PM
Spot Elevation vs. Level elevation
Wed, Feb 14, 2018 at 6:13:20 PM
Level Elevation
Tue, Jul 7, 2009 at 2:39:01 PM
11
Page generation time: 2.3312
