75 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> deleting construction pink lines
![4 Stars: 5 Votes](/images/stars_4.gif) |
So I opened a family to edit it. A double door. The trim extrusion needs to be adjusted, but I cant. I can edit the boudary, but not delete or re-reference dimensions..in fact the dimesnions wont be deleted...no they are not locked.
note the dimesnion is black...meaning its there while you are editing. I cant ddelete that one. or the pink lines...
Michael
Click on the top sketch line...then edit the dimension that is available.
I had to delete the extrusion. I could not do anything to the dimension or the line.
Pink ductwork |
Fri, Sep 14, 2012 at 8:53:22 AM
Sheet DWG exports appeat PINK in autocad |
Wed, Apr 10, 2013 at 7:54:45 AM
historic construction slow-down [ 1 2 3 4 ] |
Sat, Oct 29, 2011 at 4:37:51 AM
45
Cut Profile Visibility Settings |
Thu, Feb 18, 2016 at 12:45:19 PM
Deleting Room Separation lines |
Mon, Apr 14, 2014 at 1:18:11 PM
Members: | 2017373 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
