86 Users Online (85 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> DWG export, separating materials..?
Tue, Apr 16, 2013 at 5:09:30 AM | DWG export, separating materials..?
Kauristedt
Hi,
I'm struggling on the matter to separate different materials in to their own layer when exporting to dwg.
Walls/Floor (more) - concret, wood, steel.. etc
but so far I cant find the solution. Somebody know if its possible and then how? If not possible, do you have any trick/tips on how I could go around it?
/Kautar
Thu, Apr 18, 2013 at 5:02:35 PM | DWG export, separating materials..?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
The only thing you can do is assign the REVIT wall structure layers function to an autocad layer. Not quite 'material' related but pretty close.
Click the big purple R > Export > Then schroll to the very bottom 'Options' > Export Setups DWG / DGN > Then open up Walls under Model Categories and map the REVIT Layer function to an AutoCAD layer name. See images.
Export 3d DWG issues
Fri, Jun 28, 2013 at 8:27:02 AM
Export for VIZ, or anything else...
Thu, Jul 20, 2006 at 3:50:31 AM
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches?
Wed, Feb 11, 2009 at 4:42:25 PM
EXPORT TO DWG - Problems
Wed, Feb 22, 2012 at 2:28:53 PM
Export Linework colors to DWG
Wed, Sep 14, 2016 at 12:04:12 AM
Page generation time: 0.8218
