79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> inserted dwg view problem in 2013
Mon, Apr 15, 2013 at 9:56:42 AM | inserted dwg view problem in 2013
sllana
5 Stars: 2 Votes
Hi people, I have been having a weird problem when inserting a dwg, either as a link or as an impor,t in the revit 2013, and it consists in a dephased appearance of the lines. In earlier versions when this happened, I just exploded the hatches and polylines and blocks and the problem disappeared, but now it persists yet doing the same. Any tip?
Mon, Apr 15, 2013 at 10:05:23 AM | inserted dwg view problem in 2013
Never heard the term "dephased" so please post something to help us understand.
ALWAYS - Try not to explode DWG's.  Do that in a clean up project - then convert all the text, dimensions,lines and fill patterns to your standard.
Mon, Apr 15, 2013 at 10:20:14 AM | inserted dwg view problem in 2013
sllana
5 Stars: 2 Votes
well I mean: moved. Lines out of their place. (desfasadas, corridas) Misplaced. In another post someone called it "dancing lines". And by the way: using that post I refer to, seems to work. Im gonna comfirm later. Thank you Hub for your immediate responses.
It is incredible how one can ask a question to the whole world at the same time just from your desk. Thanks again.
Fri, Sep 6, 2013 at 12:38:38 AM | inserted dwg view problem in 2013
cookaaron20
I'm having a similar problem and I to do not know how to explain the problem. I like the "dancing lines" description. Did you find an answer? Is it something to do with having to convert polylines to line segments in the dwg before importing?
Tue, Oct 29, 2013 at 5:24:28 AM | inserted dwg view problem in 2013
Melshimber
I have come across this problem and the lines dance around as you zoom into the object.
The cause is that your linked dwg model is not centred to co-ordinates 0,0,0.
If you amend the linked cad file to the co-ordinates then Revit will be able to handle the files correctly.
Reference DWG disappearing when zoomed
Mon, Jan 2, 2012 at 2:28:44 PM
Locking inserted image/dwg file
Mon, Aug 29, 2011 at 9:38:26 AM
Update Inserted DWG
Mon, Dec 13, 2010 at 1:08:49 PM
Why does my Imported .dwg dance???
Thu, May 11, 2017 at 6:33:52 AM
11
Dwg export: revit 2013 ignoring subcategories
Thu, Jul 25, 2013 at 8:12:44 AM
Page generation time: 2.8375
