Forums >> General Discussion >> Revit Project Management >> Making the switch from Autocad Arch to Revit today
So my company has decided that this afternoon we will switch from Autocad Arch 2013 to Revit. I've played around with it some the past week on the demo and modeled a few buildings going only as far as windows, doors, floors, etc. I'm really excited how smoth everything seems to flow so far in the little I've used it. My question is ...... Does Revit use plotstyles like CAD with lineweights or is it totally different? My first task is to build our company border and set up all plotting styles and sheet sizes per upper management. I've yet to plot anything in Revit so I was just wondering what tips or problems anyone could make me aware of when attempting this wonderfully boring task? I look forward to getting to know you guys / gals and look forward to learning Revit in & out to the best of my ability. This site looks like a very useful tool. Thanks in advance for any advice.
West
plotting is what you see is what you get. its all based on viewscales not layers, colors, plot styles, etc... takes a little time to figure out exactly what you want so keep it simple to start. begin with a title block then use all your linetypes in different scale drafting views to see how they compare side by side. They Revit out of the box settings are pretty good although i have tweaked mine quite a bit over the years.
First rule - Don't think CAD AT ALL!
Take some time here to learn the product. You can't jump in and expect to do a full project without some initial training. Setting up sheets is an OK start but even that is so different from CAD that you may run into problems.
Learn to use your HELP. Have you read the topics under this yet? If not, your off to a bad start.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/1926-Prepare_1926/1956-Title_Bl1956
Well West my friend you have your work cut out for you, so hold on tight. Creating custom title blocks is no small task and in my opinion should definately NOT be done by someone who is just starting out. Especially if you want it to look and behave like your existing title block. Unfortunately that's always the first thing you have to get done and it will numb your sense of accompishment before you even get out of the gate.
I can however do that for you at a cost so you get off on the right foot and your boss is happy. To do otherwise is to enter into a heap of anguish, struggle and frustration.
Plotted line weights are first and formost controlled by 'object styles', then the views can override those settings. The out of the box REVIT lineweights are generally too thick and need a quick overhaul as well as the object style settings.
I suggest you invest in the videos listed from the web site listed below.
On a difficulty scale of 1 - 10, creating a custom title block with shared parameters, project parameters and a project template is around a 6. You are probably a 0 at this point.
Above and beyond title block families you also need a 'project template file'.
This is very typical. The decision is made and the boos expect it to 'just happen'. Trust me on this one, it doesn't 'just happen'. It takes some professional assistance and training.
The decision has been made. Great, now the real work begins.
My 2 cents : )
Thanks for the reply guys! Especially to WWHub for the help section advice and link. Think I will pass on paying someone to set up my sheet borders though dgcad, although it's much appreciated. I'm pretty sure with the help of the link WWHub supplied I've got them set up. So far so good anyway. Although I will agree it's much different than using cad the last 23 years! Hopefully with some time and dedication I can jump from beginner to novice pretty quickly at least. I'm keeping my mind open and my fingers crossed.
As long as you stick to the out of the box information fields that REVIT provides you'll be ok. If you have a data field in your existing title block that doesn't appear in REVIT's list, thats when it gets tricky. Perhaps compromise a little with that aspect until you get out the gate.
Keep going West.
Keep going West.
If you are in the US, just be prepared when you reach the Pacific Ocean
Just pull a Forest Gump. Turn around and head East. heheheh
I like the simplicity of revit's lineweights. Color coding was nice in cad, I guess, but with the ability to toggle thin lines on and off, you can switch between exact drafting and seeing how the drawing will plot with touch of a key.
we've redone our lineweights, deviating from the standards a bit-- but use line weights from 1-7, and these suit all of our needs for all objects and annotations in all view types.
1 = furniture in plan, insulation cut in details, site details
2= plywood cut in details, walls cut in plan
3= wall cut in section, column cut in plan
5= cut steel and concrete
etc. I could be wrong--we have these set as project standards so I don't even have to worry anymore. It takes awhile in Object Styles to settles upon standards that you (or your boss) like, but then it's smooth sailing.
Need help in trying to Convince Office to switch from ADT to REVIT [ 1 2 ] |
Tue, Jan 8, 2008 at 10:23:23 AM
16
suite or plain Revit Arch? |
Thu, Nov 1, 2007 at 8:54:15 AM
CD coordination of Revit among other disciplines using AutoCAD |
Fri, Apr 12, 2013 at 2:05:46 AM
Switch ID Grayed out in Revit MEP |
Tue, Feb 26, 2013 at 11:33:36 AM
I can't assign a switch ID to a switch |
Wed, Dec 9, 2020 at 5:42:46 PM
Members: | 2022280 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
