48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revit Families & Types
Tue, Apr 9, 2013 at 4:49:38 AM | Revit Families & Types
OneAlex
OneAlex Avatar
Morning All,
Im looking at combining a number of individual pump family files into a single family. Selection then can be made from the type drop down once understood.
As it currently stands the pumps are not parametric so heights etc cannot be adjusted on each pump. They are individual blocks....So how do you get that pump block to appear to each of the family types? Its the link I just cant get my head around!
An image is attached, I may be going the wrong way about this?
Alex
Tue, Apr 9, 2013 at 6:53:43 AM | Revit Families & Types
OneAlex
OneAlex Avatar
Disregard my question, Ive managed to resolve the issue.
Solution:
Input the blocks into a single family.
Using parameter types you can set up a visibility parameter.
Then on family types you can link these so the block changes when you select the diffrent sizes of pump.
Cheers
How to delete all the unused families and types in REVIT 2015
Fri, Jan 9, 2015 at 7:54:25 AM
Why not use nested families for multifamily unit types?
Tue, Mar 7, 2017 at 10:09:34 AM
Replacing Multiple families in a Project.
Mon, Oct 15, 2018 at 10:34:29 AM
Break Line & Weld sybol families
Wed, Apr 28, 2010 at 9:18:41 PM
NBS specification & Revit
Thu, Feb 3, 2011 at 3:25:20 AM
Page generation time: 3.4517
