72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> insert piece of pipe btween two
Mon, Apr 8, 2013 at 1:23:04 AM | insert piece of pipe btween two
frifer
5 Stars: 4 Votes
hi guys!
please watch the image attached.. it happens often to me that i have to insert such piece of pipe but the hight is not a decent number (to palce the working plane on it) but something like 1245,22... is the only way of working with pipes to place a plane at the correct height and then draw away or is there a better solution? how would you put this missing piece of pipe in?
thanks!
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback Shadey http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381
Mon, Apr 8, 2013 at 2:18:10 AM | Pipe Visibility
krishan
krishan Avatar
3 Stars: 10 Votes
When i rotate my project at specific angle, The visibilty of pipe are brust (not smooth),
Please provide the solution if anyone know about the problems.
Mon, Apr 8, 2013 at 8:39:22 AM | insert piece of pipe btween two
frifer
5 Stars: 4 Votes
hi krishan! you better make your own topic else probably nobody will see it.
Tue, Apr 9, 2013 at 6:16:07 AM | insert piece of pipe btween two
frifer
5 Stars: 4 Votes
nobody?? Sad
Btween program convert files
Sun, May 21, 2006 at 5:29:41 PM
Trim HSS Round pipe into another HSS Round pipe
Tue, Apr 3, 2012 at 4:39:45 AM
pipe dimensions
Wed, Dec 2, 2015 at 7:47:03 AM
Pipe Accessories and Pipe Type parameter
Tue, Dec 27, 2011 at 11:25:39 AM
Pipe Branch Takeoff/Gain
Fri, Feb 26, 2016 at 12:29:37 PM
Page generation time: 0.3434
