24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Array with progressive rotation and spacing
Fri, Apr 5, 2013 at 11:55:17 AM | Array with progressive rotation and spacing
kubbah
Hello,I would like to achieve this result with elements in a row:A: the spacing is progressively biggerB: the spacing and rotation is progressively bigger
as per imagehttps://docs.google.com/file/d/0B9wW_0_r5bZqdURYWVc3b2JsSFE/edit?usp=sharing
Could anybody tall me if revit is capable of such a thing without switching to Rhino?
Thanks a lot
Sat, Apr 6, 2013 at 7:17:25 PM | Array with progressive rotation and spacing
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Yes, Revit can do that with Divide & Repeat. No need to Rhino.
Planta1 Revit Online Consulting | info@planta1.com
Sun, Apr 7, 2013 at 1:47:19 PM | Array with progressive rotation and spacing
kubbah
Thanks a lot,
could you give more details of the process?
Sun, Apr 7, 2013 at 2:07:55 PM | Array with progressive rotation and spacing
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Since the process includes several steps, I respectfully recommend you to visit Zach Kron's blog, Buildz. Search for the topics on Divide & Repeat. He has some videos explaining how to create variations in the repeater.
Tue, Apr 28, 2015 at 11:55:53 AM | Array with progressive rotation and spacing
njitrrr
alfmedina, the image that you attached is exactly what I am trying to do.  I am not finding the Buildz video that shows me how to create a rail that will divide and repeat like you are suggesting.  I will keep searching, but if you get this, could you respond with the direct link?
Tue, Apr 28, 2015 at 8:47:42 PM | Array with progressive rotation and spacing
ronmalit
5 Stars: 3 Votes
http://buildz.blogspot.sg/2012/06/repeat-and-divide-prt-iv-reactor.html
** dont be mad, i dont have much... i am homeless
Is Solution to Creating a Parametric Polar Array?
Tue, Oct 22, 2013 at 8:40:07 PM
Array component with rotation
Thu, Oct 8, 2020 at 6:53:42 AM
ARRAY INSIDE A FAMILY
Fri, Oct 12, 2007 at 12:41:18 AM
Variable Length Family with Array Formula
Wed, Aug 8, 2012 at 9:56:47 AM
how can I array along spline? [ 1 2 ]
Fri, Nov 28, 2008 at 7:07:33 AM
19
Page generation time: 1.1410
