Forums >> Revit Structure >> Technical Support >> Linked Revit Model Sheets
32 Posts No Rating |
Hello,
I am working in Revit Architecture 2013. I linked a Revit model from a project that had all of the architectural drawings. I did not create either Revit file; I was just asked to coordinate everything. I edited the fields so that the sheets from the linked file show up in the index, however I cannot move them to the Architectural discipline. Someone had already set up all the architectural sheets correctly, but since they didn't know how to link the models, they are merely placeholders. How can I "replace" those sheets with the linked model sheets. I am sending this model to a contractor, so how will they be able to view these linked sheets in the central file?
Thank you very much in advance,
Margaret Frank
If I need to create a Shared Parameter to order the sheets from the linked model, how exactly do I set that up?
You should not have any "sheets" for the linked model in your project so if someone made up dummy sheets you will want to delete those.. Simply include them in your index schedule but checking the box to include linked models.
NOTE: If you think you will have their actual sheets in the model, you are mistaken. Those sheets stay in the linked model and are printed from there.
So there's no possible way to import the sheets made in another project if they have model views?
You can't import the sheets. Sorry.
But there is no need too. The sheet names and numbers import for your schedule and printing from the other model is no problem.
I just wanted to be able to send the contractor one revit file with all the sheets instead of two, but if it's not possbile I'll send them seperately.
plotting sheets from a linked model |
Thu, Oct 16, 2014 at 11:11:01 AM
Base building model, fitout model and sheets |
Wed, Jun 5, 2013 at 5:42:52 PM
Where should I create sheets? (Linked Revit) |
Wed, Jun 28, 2017 at 1:02:33 AM
sheet index order with Linked models |
Sun, Mar 13, 2016 at 12:37:27 PM
copy drafting views from linked model |
Tue, Feb 15, 2011 at 9:44:11 AM
Members: | 2106051 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
