68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Copy room identity Data
Fri, Apr 5, 2013 at 7:01:30 AM | Copy room identity Data
SteveB
3.5 Stars: 5 Votes
is there a way to copy the room identity data from one room to additional rooms, rather than fill it in each time.  Of course I can make a schedule key, but just curious.  match type properties doesn't function with rooms.
Fri, Apr 5, 2013 at 7:26:17 AM | Copy room identity Data
Copy the whole room then rename & renumber.
DON'T USE SCHEDULE KEYS unless you truely understand them.  The data is not with the room but with the key.  Therefore you can't change any individual item without changing the key.  This should be on a wish list.  To be able to unlock the schedule key from the room and allow the data to then reside with the room.
Fri, Apr 5, 2013 at 8:16:51 AM | Copy room identity Data
SteveB
3.5 Stars: 5 Votes
copy and paste rooms works, thanks.    We do use key schedules for rooms.  Great to be able to have room types, then assign the various finishes, properties, etc in one step to multiple rooms, leaving fields out of the key schedule where they will be individually chosen.
Fri, Apr 5, 2013 at 9:02:41 AM | Copy room identity Data
Schedule keys work great.  We just had problems with users that did not understand them.  They wanted the same finishes in a room as another room i the schedule but that information was not in the pull-down because it was in a schedule key.
You can't even copy paste key schedule information from one cell to a non-key schedule cell while in a schedule.
room system families: adding identity data
Tue, Aug 5, 2008 at 5:24:14 PM
Identity Data
Thu, Oct 6, 2005 at 10:21:03 PM
Editing existing Identity Data in a Family
Tue, Sep 22, 2009 at 12:34:42 PM
Delete Identity Data
Mon, Sep 30, 2019 at 7:05:26 PM
Adding formula to change identity data and heights of components
Mon, Oct 21, 2013 at 5:02:09 AM
Page generation time: 1.8613
