Forums >> Community >> The Studio >> Just created my first Family
160 Posts No Rating |
I have just created my first window family. I needed a window for the side of a dormer so I made one !! voila. But its not perfect yet, I need to work out how to make it fit in a wall either way. As it has a corner cut off one side I need to make it flip to work in a wall both ways.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
It feels good to accomplish something andk now that you are improving your Revit skillset. Congrats
Thank for the encouragement. Any clues on how to make my window (with on bottom corner cut off) to work on either side of the dormer in the image???
Cheers Dermot
www.dmbd.net |
Wouldn't it be fine just using the flip control?
That does not seem to work. I may have to make a left & right version as it soes not flip the cut off at the bottom corner where it is supposed to align with the main house roof.
See the image attached
Cheers Dermot
www.dmbd.net |
The flip control should solve this problem. Are you putting the correct flip in ??
Lost me there, correct "flip" ??
Cheers Dermot
www.dmbd.net |
Insert a regular door and note the two flip icons when you click on it.
That's what you need. In the family you can add horizontal and vertical flip controls.
I'm pretty sure that's what you need.
I understand the flip controls with objects like doors & windows, but not how to concieve them in a family. (Is concieve the correct terminology in familes?? ha ha)
Cheers Dermot
www.dmbd.net |
