78 Users Online (77 Members):
Forums >> Revit Building >> Technical Support >> Elevations showing items behind walls
7 Posts No Rating |
Hello,
We are having issues with a couple elevations in a project.
We are seeing floors and walls (only ones that are touching the external walls and roofs etc). it is strange.
We have checked Hidden line, the elevation is parallel to the wall. It happens when using host view and even on linked view when the building file elevation looks fine.
As you can see from the attachment the top pic is the elevation from the building file and the bottom pic is what we are getting in the site/project file.
Can anyone shed some light on this for us?
Cheers
Seems like you have a "graphic card" issue, try to update the drivers.
67 Posts No Rating |
what if you do shaded or realistic? I know you want it black and white but lets see if its an issue with that view mode or something else.
0 Posts No Rating |
I am currently having the same issue, but this thread does not have a solution.... Does anyone know the solution?
The unique thing to me is that is only happen on a few elevation and not all of them!
Show us your view settings.
ARe there any filters?
Is there any phases?
Building Not Showing in North/West Elevations |
Mon, Aug 18, 2014 at 11:44:38 AM
Beams not showing in Elevations |
Sat, Jul 18, 2009 at 3:13:15 AM
Families that are "behind" cut showing up in interior elevations. |
Wed, Jan 23, 2008 at 10:50:16 AM
Columns not showing up in elevations?? |
Wed, May 31, 2006 at 6:18:44 PM
In shaded View walls/roofs are showing material and lines behind them |
Tue, May 28, 2013 at 9:35:44 AM
Members: | 2017196 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
