20 Users Online (19 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Multiply schedule field values
Thu, Apr 4, 2013 at 2:04:00 PM | Multiply schedule field values
jpmays23
Hi all,I have created a schedule of some parameters of a custom family that I made.  Among those are Length and Width.  Instead of creating a field for Area, which gives me the total surface area of my object, I just want the Width X Length. I attempted to create a Calculated Value, which was Width*Length, but I get this error:  "The following is not a valid schedule field: Width", even though I selected it from the list of available fields by clicking on the box with 3 dots.  Anyone come across this, or know a workaround?  Does it have something to do with it being a shared parameter from the family I created?Thanks,JP
Thu, Apr 4, 2013 at 2:15:42 PM | Multiply schedule field values
We have no knowledge of what your parameters are.  You created them so tell us more:
Be careful - The term width is available in many different families.  Shared parameters can have the same name but be from different shared parameter files - therefore they are not the same.  THE NAME DOESN'T MEAN A LOT.  << I should have said the name doesn't mean width is width.
Edited on: Thu, Apr 4, 2013 at 2:16:45 PM
Thu, Apr 4, 2013 at 2:37:31 PM | Multiply schedule field values
jpmays23
Screenshot of schedule attached.
These are Instance parameters from a custom family, that come from shared parameter Width-Shared and Length-Shared.  I also discovered I cannot select Calculate toatsl under Formatting - related?
Thanks.
Thu, Apr 4, 2013 at 3:04:44 PM | Multiply schedule field values
jpmays23
I actually found the solution.
Looks like having a dash in the parameter name was making Revit think of subtraction.  Fixed it and everything is working well now.  Still can't calculate totals, but I can live with that.
Thu, Apr 4, 2013 at 3:39:11 PM | Multiply schedule field values
I really do not know what you are doing because you don't supply enough information.  Here is a simple family and the resulting schedule that works.  I did it in 12.
Thu, Apr 4, 2013 at 4:48:03 PM | Multiply schedule field values
jpmays23
I created a simple family, which is just a rectangular extrusion.  There are several types, each with a different material.  The height property is set by type, the length and width by instance.  I wanted those dimensions to be scheduleable, so when I made a composition like the attached, it would be simple to schedule each piece, listing length and width.  That way I can simplify fabrication.  In order to make the instance parameters report, I had to also define a shared paramter (Width Shared, Length Shared) that equaled the initial Width and Length instance properties.  I also wanted to use the area to do a quick takeoff so I knew how much material to buy, but using an Area field gave me all the surface area, not just L X W.  So I wanted to use the schedule to multiply my Width Shared field by the Length Shared, giving me the area.
Schedule Calculating Field
Tue, Mar 10, 2009 at 5:25:50 AM
Ceiling Height, Formula Field in Schedule???Possible or not???
Tue, Nov 3, 2009 at 10:27:51 AM
Formulas for Schedules
Wed, Jul 22, 2009 at 2:24:29 PM
Wall schedule - level field missing
Fri, Mar 27, 2009 at 8:13:10 AM
Revit Revisions - Add field
Tue, Jan 15, 2013 at 8:23:50 AM
11
Page generation time: 1.1424
