46 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Walkthrough
Wed, Apr 3, 2013 at 1:51:07 PM | Revit Walkthrough
jenvance00
jenvance00 Avatar
I am trying to do a walkthrough in Revit 2012.  However, it is more of a walkAROUND than a walkTHROUGH.
I am trying to do a rendered, revolution of a single cabinet.
The end product will be placed in a slideshow.
 In short, I need a circulating perspective of a single cabinet.
I am not the best with walkthroughs to begin with, and this is kicking my butt!
PLEASE HELP!
Wed, Apr 3, 2013 at 2:36:40 PM | Revit Walkthrough
I suggest you simply draw a circle arout your object then pick your camera points along that circle.  Adjust the cameras seperately to point correctly.
Wed, Apr 3, 2013 at 3:04:29 PM | Revit Walkthrough
jenvance00
jenvance00 Avatar
Can you adjust the camera angles/views AFTER completing the walkthrough?
Wed, Apr 3, 2013 at 3:18:08 PM | Revit Walkthrough
Your HELP should always be your first choice:
Editing a Walkthrough Path
  1. In the Project Browser, right-click the walkthrough view name, and select Show Camera.
  2. To move the entire walkthrough path, drag the path to the desired location. You can also use the Move tool. See Moving Elements with the Move Tool.
  3. To edit the path, click Modify | Cameras tabWalkthrough panel(Edit Walkthrough).
    You can select which control in the path you want to edit from the drop-down menu. Controls affect the position and direction of the camera.
Dragging the Camera to a New Frame
  1. For Controls, select Active Camera.
  2. Drag the camera along the path to the desired frame or key frame. The camera snaps to key frames.
  3. You can also type the frame number in the Frame text box.
  4. While the camera is active and located at a key frame, you can drag the target point of the camera and the far clip plane. If the camera is not at a key frame, you can change only the far clip plane.
New to revit and have a question... Re: walkthrough on 2011
Tue, Apr 12, 2011 at 6:01:13 PM
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:51 AM
walkthrough questions
Sun, May 10, 2009 at 7:49:42 PM
walkthrough will not export
Tue, Jan 13, 2009 at 9:45:31 AM
Render a walkthrough?
Thu, Oct 3, 2013 at 8:42:12 AM
Page generation time: 3.3079
