126 Users Online (125 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Yes/No Parameter (Adding tolerance)
Wed, Apr 3, 2013 at 10:48:05 AM | Yes/No Parameter (Adding tolerance)
ericlovell
I am making a furniture piece for a project that I am doing for my office and The furniture piece has brackets to keep the countertop up. The furniture system changes in length and depending on the length, two of the brackets may or may not be there. I was wondering how I could set a tolerance for the Yes/No Parameter so they go away when the length is below a certain length? I tried putting it in, but they didn't turn off. Anyone know?
Wed, Apr 3, 2013 at 4:52:17 PM | Yes/No Parameter (Adding tolerance)
britc
Create a "Length" Parameter for the overall length.
In the Family Types Dialog Box, in the formula for your Yes/No Parameter, create an equation that reads: Length > X'-X" ...This will turn the parameter ON if it is greater than that length. Make sure you have the Visibily for each bracket set to the Yes/No Parameter.
Thu, Apr 4, 2013 at 12:41:08 PM | Yes/No Parameter (Adding tolerance)
ericlovell
Ah! I was trying less than, not greater than. That worked. Thank you
Unit tolerance
Thu, Jan 21, 2010 at 5:12:11 PM
room bounding tolerance
Mon, Mar 8, 2010 at 2:30:55 PM
pipe annotation tolerance
Thu, Jan 2, 2020 at 2:21:36 PM
Adding Parameter Groups
Wed, Apr 22, 2009 at 11:20:11 AM
My wishlist: Adding parameter in VIEW TITLE rfa
Tue, Mar 20, 2012 at 4:55:01 PM
Page generation time: 0.4302
