99 Users Online (97 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> loading custom doors.
Tue, Jan 31, 2006 at 4:18:47 PM | loading custom doors.
dvsone78
I created a custom door to just be one static size and when i try and load it, it errors is there anything specal that you need to do to the door when you create it to make it load into a project.
Tue, Jan 31, 2006 at 4:55:34 PM | RE: loading custom doors.
Rythmick
5 Stars: 2 Votes
There is nothing you need to do other than have it work error free within the family editor. Try changing the wall thickness or create another type with a new parameter to see if you can get the family to show it's error. If you can not find the error you can post the family and perhaps someone can take a look.
Tue, Jan 31, 2006 at 7:07:46 PM | RE: loading custom doors.
dvsone78
i figured it out what ever was wrong it was because i had two manny different extrusions in the family or rather i resovled the problem by combinding familys... maybe it was because the extrusions where over lapping and maybe faimlys can not be loaded when they do that... maybe you could elarberate.
Problem loading components
Mon, Sep 28, 2009 at 3:43:40 AM
Loading a Custom Curtain Wall
Mon, Mar 8, 2010 at 1:24:47 PM
Loading Custom Curtain Wall Panel into file
Mon, Sep 15, 2014 at 9:19:41 AM
How do I make custom wall types publicly accessible?
Sun, Apr 4, 2010 at 2:17:08 PM
Doors on North wall showing up on South elevation
Sat, Feb 4, 2017 at 5:21:33 PM
Page generation time: 0.5467
