Forums >> Revit Building >> Technical Support >> Walls with Split surfaces don't show in view
Tue, Jan 31, 2006 at 3:54:08 PM | Walls with Split surfaces don't show in view
cranko
We have a model where we have split some surfaces on a bathroom wall to show tiles half way up the wall. This has resulted in the walls not showing up in the plan view. We have tried visibility settings, worksets etc all without success. Has anyone else had this problem, or can suggest some solutions? Thanks
Tue, Jan 31, 2006 at 4:06:53 PM | RE: Walls with Split surfaces don't show in view
cranko
Further investigation shows that it is only the EXTERIOR walls that are affected. We have split interior walls with no problems When i remove the split surface from the wall they reappear...
Turning floor surfaces off for individual floor elements?
Thu, Jun 29, 2006 at 1:31:20 AM
Walls don't show in section view
Fri, Oct 26, 2012 at 12:30:09 PM
Can't split certain faces
Thu, Dec 6, 2012 at 6:59:31 AM
using split face tool on curved walls
Sat, Oct 12, 2019 at 8:21:20 AM
Separating walls
Mon, Jul 3, 2006 at 8:18:21 AM
Page generation time: 1.9484
