77 Users Online (74 Members):
Forums >> Community >> Newbies >> inserting Center to Center
1 Posts No Rating |
Good day eveyone. I have been using Revit for awhile and for the first tme ran into a question on why would you want to use Center to Center insert option when inserting a deg file? Is there a real reason on why we would need to use this other than using orgin to orgin.
AdvanceTEC
www.AdvanceTECLLC.com |
When shared positioning has not been used, I often use center to center then I move the linked(inserted) element manually.
There was a very good article a couple of years ago in AUGI Edge about Revit's origin. You should look for that.
Center to center as default for importing |
Fri, Feb 19, 2010 at 11:01:45 AM
Inserting Links |
Fri, Mar 17, 2017 at 7:44:17 AM
Dimension center line of foundation |
Thu, Oct 4, 2007 at 7:40:43 AM
dimensioning to a center mark of an arc |
Wed, Jul 5, 2023 at 3:13:09 PM
Center Reference Planes....... |
Tue, Jan 30, 2018 at 9:48:46 AM
Members: | 2017271 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
