72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Wishlist >> material tagging a family
Mon, Apr 1, 2013 at 7:34:34 PM | material tagging a family
csheets
How do you allow a material tag to recognize an assigned material in a family?
I've got a panel family which I've added a material parameter to the family type. Once imported into my project, I select the appropriate material from within the project, but when I try to material tag it, it does not recognize any material.
Is there a specific way the parameter needs to be set up within the family?
Mon, Apr 15, 2013 at 4:12:47 AM | material tagging a family
ronmalit
5 Stars: 3 Votes
hi
hope its not too late to answer
yes there is! when you do a material tag, make sure set your detail level to fine. then you can also tag all the structure construction/layer of wall.
after tagging, you can set it back to coarse level if you must
** dont be mad, i dont have much... i am homeless
Tagging Subregions in Topography
Mon, May 21, 2012 at 7:45:11 AM
Tagging a family within a family
Mon, Oct 8, 2007 at 3:24:36 PM
Tagging, naming or labeling an extrusion in a family
Fri, May 19, 2017 at 1:31:25 PM
Tagging In-Place Families:
Wed, Oct 10, 2007 at 7:20:26 PM
Material tag not tagging!
Fri, Apr 17, 2015 at 7:38:03 AM
Page generation time: 3.3167
