81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> plotting
Fri, Mar 29, 2013 at 12:05:02 PM | plotting
ERICLH
WHEN PRINTING IN REVIT 2013 I RANDOMLY GET DOUBLE PRINTS? I GET THIS USING TWO DIFFERENT PRINTERS AND WHEN I USE THE ADOBE PDF. I CAN PDF 5 SHEETS AT ONCE AND IT ONLY DOUBLES ONE SHEET? PLOT SETTINGS ARE SET TO ONLY ONE COPY IS THERE A WAY TO FIX THIS?
Fri, Mar 29, 2013 at 12:55:50 PM | plotting
This is probably a driver issue.  We don't get any double printing to plotter or to PDF's.  We sometimes plot 20+sheets to one PDF file with no problems.
I never print multiple files to single ouput because of naming problems so one plot at a time for one file.
Thu, Apr 25, 2013 at 11:22:00 AM | plotting
Vertech228
We see this exact same problem in Revit 2013.  I haven't found a solution to it either.  It only occurs when printing to our Xerox 510 wide format printer.  Printing to PDFs does not exhibit the double print issue for us.
plotting to a plotting service plotter with a prn file
Wed, Jun 4, 2008 at 1:14:57 PM
Plotting PDF's
Tue, Jul 21, 2009 at 4:18:06 PM
Plotting HELP!!
Tue, Nov 14, 2006 at 3:13:11 PM
Plotting
Fri, Apr 28, 2006 at 8:31:03 PM
plotting problem
Wed, Dec 22, 2004 at 3:44:52 PM
Page generation time: 0.2096
