94 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Working on a linked file
Fri, Mar 29, 2013 at 12:00:16 PM | Working on a linked file
crosado
scenario:
- I am given a project file (OTHER) from a client
- I will link OTHER into my file (HOME)
- my job is to populate the walls of OTHER with studs using a revit add-in (Metal Wood Framer)
- basically, HOME will have the studs that belong in OTHER and when the two files are combined there should be no clashes
can i work on individual parts of the linked OTHER, or will my only option be to do all of my work directly on OTHER and not link it?
Fri, Mar 29, 2013 at 12:57:10 PM | Working on a linked file
A link is a link - you can not edit a link, you can only edit the file you are working in.
This user is online
Working with linked files
Thu, Oct 6, 2005 at 8:17:09 AM
Linked File Issue
Mon, Oct 14, 2013 at 7:32:34 AM
edit linked file in place or at least open linked file withou having to unload
Fri, Dec 4, 2009 at 9:57:48 AM
Linked File, how can I dimension it?
Sun, Dec 19, 2010 at 8:08:51 PM
How to make room tags in a linked file visable?
Thu, Jul 30, 2015 at 1:12:23 AM
Page generation time: 2.6922
