Forums >> Revit Building >> Technical Support >> Room boundary does not display properly
Wed, Mar 27, 2013 at 11:50:53 AM | Room boundary does not display properly
nelrock
Hi, I'm using Revit 2011 and having an issue with two rooms where the boundaries do not correspond with the walls (see attached images, Rooms 108 & 113). I have not drawn any room boundary lines, but intend to use the walls enclosing the rooms to define the area.  You can see in images 01 and 02 that the room does not extend all the way to the exterior walls.  I have checked to make sure the rooms are bounded on all sides, top and bottom and they appear to be.  Images 03 & 04 show that these rooms have floors and ceilings.  Any ideas?
Wed, Mar 27, 2013 at 12:14:25 PM | Room boundary does not display properly
First - Rooms are level based and room bounding elements must intersect the level.
In your case, a basement wall must be bounding the room.
Did you hide something?
Are you phasing this somehow?
Wed, Mar 27, 2013 at 1:51:25 PM | Room boundary does not display properly
nelrock
Thanks!  I think I figured it out.  Looks like it had something to do with the level it was associated with.
Room boundaries woun't properly display
Tue, May 15, 2018 at 3:08:14 AM
Structural column doesn't define room boundary (but only sometimes!)
Wed, Apr 1, 2015 at 10:23:56 AM
Room Boundary Issue [ 1 2 ]
Tue, Sep 11, 2012 at 12:46:42 PM
21
Room Separation Lines won't display [ 1 2 ]
Mon, Feb 19, 2018 at 2:00:11 PM
15
Room boundary issue
Sat, Sep 21, 2019 at 8:21:34 AM
Page generation time: 0.5791
