Forums >> Revit Building >> Technical Support >> Wall Sweep at the Corner
32 Posts No Rating |
Hello,
I am working in Revit Architecture 2013. I have various wall profiles/heights that I applied wall sweeps to to show coping. I am trying to figure out a way to make the wall sweep go over the corner or miter. How can I do that?
Thank you,
Margaret Frank
When you add wall sweeps, continue the process - don't start over on each wall. Then they will miter automatically.
So - delete all but one sweep, then pick that sweep and select add wall - on your options bar.
Some of my walls are angled though. If I didn't model those in-place, I wouldn't get the angle, right?
There are more than one way a wall can be angled.....
Obviously, if you can't place the sweep on the wall because it is angled (whatever way you mean) then the automatic miter at the corner can't happen. You have to model whatever you want.
I have walls that slope downwards. How would I go about modeling this manually?
I suppose you mean the wall is not vertical - correct?
You can do an in-place sweep. And an in place can have its path set to wrap a corner.
wall sweep inside corner |
Mon, Dec 18, 2006 at 9:07:04 AM
Corner Trim with Vertical Sweeps |
Thu, Aug 31, 2017 at 2:32:51 PM
how to make a corner sweep |
Mon, Apr 18, 2011 at 12:00:49 PM
Corner guards to snap to corner of wall |
Tue, May 13, 2014 at 12:18:44 PM
stacked wall sweep cleanup |
Fri, Feb 12, 2010 at 9:11:19 AM
Members: | 2105217 | Objects: | 23178 | Forum Posts: | 152308 | Job Listings: | 3 |
