16 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Solid fill walls REVIT 2013
60 Posts No Rating |
So, how do you make a solid fill pattern in 2013?
thanks
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
Same as you did in 2008,09,10,11,12. In your dropdown pick a solid then your color.
thanks, your right, but I was not expecting to do it via the material editor. a little different.
Revit Arch. 2009 - Floor Plan Solid Fill blocks out walls |
Mon, Mar 30, 2009 at 2:22:09 PM
Solid Drafting fill pattern |
Tue, Jun 23, 2015 at 1:35:01 PM
Solid Fill Pattern |
Wed, Jan 9, 2008 at 1:55:24 AM
Solid Fill Hatching |
Tue, Dec 13, 2005 at 7:11:20 PM
Bearing walls solid fill |
Tue, May 17, 2005 at 10:54:56 AM
Members: | 2026030 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
