Forums >> Revit Building >> Technical Support >> Instance parameter override problem (+ scheduling)
Sat, Mar 23, 2013 at 2:12:55 PM | Instance parameter override problem (+ scheduling)
jpmays23
I have a custom family that I created which is basically a rectangular extrusion. It has instance parameter length and width and type param height. I loaded it into another family and created a composition of many pieces, adjusting their width and height. Later I realized I wanted to use a schedule to do take-offs of these lengths and widths, but I didn't originally make them reporting parameters. I went back into the original family and changed length/width to reporting and tried to reload it. When the override box pops up, it doesn't matter which option I select, they all revert back to their original length/width and all the instance properties are lost. What is happening?Also, I realized that you can't do schedules in a family, only a project file. Right now I have shadow box.rfa loaded into an .rvt file so I can do the schedules. I tried to copy and paste from the family to the project but that's prohibited too. Any suggestions to avoid having to do that? Thanks!JP
Instance Parameter connected to a Visibility Parameter for Scheduling Purposes
Wed, Mar 7, 2012 at 5:53:46 PM
Instance Parameter to control another Instance Parameter
Thu, Jul 22, 2010 at 6:22:48 AM
INSTANT PARAMETER SCHEDULEABLE
Wed, Jul 11, 2012 at 2:08:57 PM
Instance Shared Parameter??
Fri, Jul 11, 2014 at 2:49:26 PM
instance parameter on wall, fire rating
Wed, Aug 7, 2013 at 11:49:49 PM
Page generation time: 4.5401
