35 Users Online (34 Members):
Forums >> Community >> The Studio >> Plumbing fixtures not displaying
41 Posts No Rating |
Hi,
I have had this recurring problem with plumbing fixtures and furniture not displaying in particular situations or displaying incorrectly.
For instance i have a tile floor drawn as a floor type over a concrete slab. The slab is a generic slab and the tile is say 15mm thick, and 15mm above base height.
When i draw the tile floor in, some of my plumbing fixtures disappear. The other associated problem which occurs in this situation is that the tile work is visible through things like toilets and some furniture fixtures.
What are these problems caused by and how does one solve them?
the quickes solution will be to open your plumbing family and add a field region (white)...
HTH
refer http://revitrants.blogspot.com/
How do you add a field region?
DOH... sorry Mr. Spot... would have helped if i read your post! It works, thanks.
Calculating Total Plumbing Fixtures needed |
Mon, Feb 3, 2014 at 9:39:13 AM
plumbing fixtures in foundation |
Wed, Mar 22, 2006 at 10:11:18 PM
How to show plumbing fixtures on site plan? |
Fri, Jan 9, 2009 at 2:08:52 AM
Plumbing Schedule Totals |
Thu, Jan 30, 2014 at 1:05:02 PM
Revit MEP 2012 - Linked Cad Lines being trimmed by Revit Plumbing Fixtures |
Mon, Nov 7, 2011 at 12:54:25 PM
Members: | 2056525 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
