105 Users Online (104 Members):
Forums >> General Discussion >> Revit Project Management >> Custom Elevation Marker
19 Posts No Rating |
Hello all,
I am trying to edit the default spot elevation tag to customize to our views. What I want to do is add the word AFF after the dimension automatically and place a text box below the elevation so that the drafter can type up a description. For example for a counter height I want to have:
2'10" AFF
______________________________
Countertop
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
You can add a prefix or a suffix to the spot elevation through the properties of the marker. The spot elevation is a systems family an you cannot add a label to the family to get it to read "countertop" underneath.
Is there a way to make my own elevation marker or I have to use what is built into revit?
Text Orientation in Custom Elevation Marker |
Fri, May 6, 2011 at 10:36:12 AM
Split a an elevation marker up for mulitple sheets |
Tue, Oct 4, 2016 at 2:29:34 PM
Adding a reference elevation to an existing elevation marker? |
Wed, Sep 17, 2014 at 7:57:46 AM
ELEVATION MARKER |
Thu, Sep 10, 2009 at 2:55:39 PM
If your elevation markers on plan disappear. |
Fri, Mar 4, 2016 at 3:40:45 PM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
