54 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> walkthrough path shape
Fri, Mar 22, 2013 at 1:49:41 PM | walkthrough path shape
Warchitect
4 Stars: 5 Votes
So I am trying to make a walkthrough where I fly around the building in a nice even cricle. if I use four camera key points my path is sort of rhomboid. and not circular. is it better to use eight key camera points or am I not adjusting it right?
Warc.
Mon, Mar 25, 2013 at 7:37:40 AM | walkthrough path shape
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you try using 8 to see what happens?  I would think that the more you use the smoother the transition will be.
Mon, Mar 25, 2013 at 11:52:53 AM | walkthrough path shape
andy777bennett
yea the number of key frames has no influence on the quality- they are only for your convenience, so put in as many or as few as you desire. The more there are the more control you have over the path, but it also makes it hard to make big changes because you have to move more points. add them and delete them as much as you need!
a thought regarding the circle, draw your circle with detail lines then you can easily move the key frames onto it :-)
Edited on: Mon, Mar 25, 2013 at 11:54:14 AM
How to export walkthrough path to Viz 2008. Need reply by 11/15/07
Tue, Nov 13, 2007 at 3:30:40 PM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008
Tue, Nov 20, 2007 at 12:37:44 PM
Revit Walkthrough Stuck
Sun, May 8, 2016 at 11:25:37 AM
Revit Walkthrough Path/Camera to 3Ds Max
Fri, Aug 7, 2009 at 11:37:27 AM
Revit 9.1 walkthrough resets camera path and active camera
Thu, Jul 19, 2007 at 11:19:34 AM
Page generation time: 1.7149
