Forums >> Revit Systems >> Technical Support >> Sketch up to revit
Is there a way for me to use sketch up files in revit? I dont have the sketchup application due to me being on a school computer and they dont allow us to download files. is there a way that i could open a sketch up file in revit? or is it only possible with Sketch up program?
Anything is possible if it off the back of a horse |
Two different programs. Edit sketchup only in sketchup. But you can insert sketchup into Revit - best through a family.
If the sketchup is a building then I strongly suggest you create it from revit elements.
I am trying to import a couple components (saddle racks, bridals, saddles, and horse models) into revit for a Barn plan. and i can only find them in google warehouse because revit doesnt have any. I already have the building made on revit and i just need the things to fill it up.
how do i import them to revit? i do Not have the sketch up program though. is it still possible to import sketchup files to revit?
It is called import.......
All of this is described in your HELP.
Start a generic family and import...
But you can't do anything if you don't at least try to do something.
I've dragged and dropped a Sketchup file into Revit before. Again, into a family so you at least have a little control over it. Otherwise, export the sketchup as .dwg and LINK it in or bring it into a family file. Apply materials and away you go.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here |
Check the following:
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/0066-Start_a_66/0072-Using_In72/0076-Importin76/0079-Importin79
Sketch up |
Thu, Mar 15, 2007 at 6:46:50 PM
Question about sketch Mode |
Thu, Jan 17, 2013 at 6:34:56 PM
Revit into Sketch-up? |
Wed, Feb 17, 2010 at 1:08:26 PM
curtain wall sketch snapping problem |
Wed, Aug 12, 2009 at 8:54:07 AM
Problem Rendering Sketch-up Components in Revit Arch 2009 |
Tue, Dec 9, 2008 at 1:08:36 PM
Members: | 2124087 | Objects: | 23216 | Forum Posts: | 152313 | Job Listings: | 3 |
