81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> CBT to TXT
Thu, Mar 21, 2013 at 10:09:44 AM | CBT to TXT
rwood27
I'm trying to import our office standards to Revit for exporting the revit file.  Our layer standard is in .cbt format but Revit is looking for a .txt file.  How do I make this work?
Thu, Mar 21, 2013 at 11:10:44 AM | CBT to TXT
You don't need to do that.  Just use your file instead of the pcp file Revit creates
Thu, Mar 21, 2013 at 11:18:08 AM | CBT to TXT
rwood27
I'm trying to use the layer mapping so that I can export a plan and have the lineweights work.  Revit defaults to the AIA standard.  When I try to load file it only allows for .txt files.  I'm not sure whay you mean by using the our file instead of the pcp file.  Thanks.
Thu, Mar 21, 2013 at 12:09:55 PM | CBT to TXT
Layer mapping is different than a cbt file which is a penweight file.  You need to edit the layer mapping file to your standard.
Read this topic in your HELP:
Layer Mapping for DWG/DXF Export
Edited on: Thu, Mar 21, 2013 at 12:16:04 PM
RST 2010 keyboard shortcuts - TXT file vs Options list
Thu, Feb 11, 2010 at 8:33:17 AM
txt file with families
Wed, Jun 13, 2018 at 4:10:35 AM
IMPORTING / LINKING; XLS / TXT
Fri, Jun 23, 2006 at 3:08:39 PM
Excel to comma delimited txt file
Mon, Mar 16, 2009 at 10:57:04 AM
Revit 2011 - where is keyboardshortcut.txt?
Thu, Dec 30, 2010 at 7:17:52 AM
Page generation time: 0.4661
