30 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> how to make material pattern specific to instances?
15 Posts No Rating |
Hey yall,
I'm using Revit '11. I was wondering if there is any way to make surface (model) patterns specific to instances oppose to types. Specifically, I want to align wall tiles to a particular corner of a room. But if that wall runs along a series of rooms, how can I make the surface material pattern align in the corner of each and every room. As of now I have a wall that runs along a corridor and on the other face of the wall a bunch of rooms. In my interior elevations I want the wall panels to start in a specific corner but I am having to do multiple fill regions in every interior elevation because the pattern is designated along the wall type, not the instance. Any way to change this? Or am I doomed to multiple fill regions with little holes in them to allow keynote to identify material?
Thank you!
We use a thin wall for tiles and is placed only in the room, aligned agaist the base wall and joined to it. That thin wall is usually a stacked wall because it may be base - wainscot cap rail instead of full height tile.
Hiding Surface Pattern For Specific Wall Material |
Thu, Feb 21, 2008 at 10:47:29 AM
hatch pattern in material anomolies |
Fri, Aug 26, 2016 at 9:35:26 AM
Split Faced CMU model material pattern help???!?!?!? |
Fri, Jun 1, 2007 at 2:01:39 PM
Where is pattern setting in material browser |
Thu, Jul 26, 2018 at 1:52:03 PM
how to know the material used in a specific object? |
Mon, May 9, 2011 at 1:14:23 PM
Members: | 2019206 | Objects: | 22958 | Forum Posts: | 152184 | Job Listings: | 3 |
