130 Users Online (129 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Cannot access Forms Tab or Detail Sketch Tab
Tue, Mar 19, 2013 at 9:29:45 PM | Cannot access Forms Tab or Detail Sketch Tab
CosmicTraveller
Hi! I'm new to this forum as well as Revit. I'm hoping this website will help me with some of the problems that can occur with Revit. I am using Revit 2013 Ultimate on Win 7 Pro 64. My problem right now is I don't seem to have any access to the Forms Tab or the Detail Sketch Tab! Not sure if I've missed some kind of Add-on. I am trying to cut the inside perimeter of my Grade Beam 2"x 5" to support part of my 5" Floor Slab. I figured that a simple sweep cut or (Void) cut would do the trick but am not sure if this is even the right approach.
Thanks
Paul Rymal
Wed, Mar 20, 2013 at 7:33:57 AM | Cannot access Forms Tab or Detail Sketch Tab
3.5 Stars: 395 Votes
You don't say how much experience you have so we usually start at the beginning.
Do you know how to mdel in-place?
Do you mean you are missing the following?
Wed, Mar 20, 2013 at 9:51:39 AM | Cannot access Forms Tab or Detail Sketch Tab
CosmicTraveller
Hi I've been using Revit for just over a year now but mainly on a learning mode. I took a 1 week course through our Autodesk dealer on "Revit Architecture". Then I spent close to $700.00 on Ascent Training manuals for Revit Arch, Struct & MEP I've gone through all but the MEP & the BIM book. What a learning curve, but I'm slowly getting a feel for it. Sure need the support though. The image you have shown in your reply is exactly what is missing. I've tried to reload my Tools etc. from my Software but still can't find any add-ons. Any help would be much appreciated.
Thanks
Paul
Wed, Mar 20, 2013 at 10:38:16 AM | Cannot access Forms Tab or Detail Sketch Tab
That toolbar does not come up until you start the model in place process.  Component / model-in-place.
READ YOUR HELP:
Creating an In-Place Element
Wed, Mar 20, 2013 at 12:11:10 PM | Cannot access Forms Tab or Detail Sketch Tab
CosmicTraveller
Gotcha! Thanks! I talked to Autodesk & they said the problem was I had to download "Exrtensions"! That didn't do much. This is why forums are so important especially with this program. Do you have any suggestions as to how I would do a simple swept (void) around the inside perimeter of my grade beam. Its simply a square cutout 2" wide & 5" deep on the inside portion of the grade beam for the slab to rest on.
Thanks again!
Paul
Wed, Mar 20, 2013 at 1:25:27 PM | Cannot access Forms Tab or Detail Sketch Tab
This is not really a classroom.  You need to do some research on how you create objects.  Get a book and read your Help.  There are a lot of videos out there to.  Come back if you run into a particular problem.
Wed, Mar 20, 2013 at 2:41:15 PM | Cannot access Forms Tab or Detail Sketch Tab
CosmicTraveller
O.K. I thought this was like the  WAUN or Augi Forums!
Sorry for the bother
Paul
Thu, Mar 21, 2013 at 8:14:55 AM | Cannot access Forms Tab or Detail Sketch Tab
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This is like an Augi forum however your not asking a question on a problem or why something won't work, you are asking how to do it.  The best way to find out how to do something is either try it and see what happens or look in your help. Look up Sweeps and Void Geometry and try out a few different options.  If you cant figure it out you will get more help once you tell us what you tried to do and errors you are getting etc.
Elevation Tab
Mon, Sep 19, 2016 at 10:13:48 AM
No Annotate tab in Family Editor; no detail lines
Tue, Sep 8, 2009 at 3:42:49 PM
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
How to get structural tab?
Tue, Apr 15, 2014 at 12:22:56 PM
No Add-ins tab in my ribbon
Wed, Oct 17, 2012 at 9:27:01 AM
Page generation time: 0.8340
