78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Display Room Names for Double Volume Spaces on 2nd Floor Plan
Mon, Mar 18, 2013 at 9:59:59 AM | Display Room Names for Double Volume Spaces on 2nd Floor Plan
leothelionator
What is the agreed upon method for room labeling double volume spaces from the first floor plan onto a second floor plan (elevator shafts, stairways, double volume lobbies, etc)?  Is there a way to get the 1st floor space to read on the 2nd floor plan without creating a new room?  Or do I create a new room for the 2nd floor stairway?  Or do I just write dumb text such as "LOBBY OPEN TO BELOW"?
Mon, Mar 18, 2013 at 10:35:47 AM | Display Room Names for Double Volume Spaces on 2nd Floor Plan
Rooms have a height value that can be set.  Then the room will tag correctly on other levels.
Mon, Mar 18, 2013 at 10:46:29 AM | Display Room Names for Double Volume Spaces on 2nd Floor Plan
leothelionator
Thanks, that did the trick.
Room Tags not showing up in Floor plan.
Tue, Nov 9, 2010 at 1:06:50 PM
I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
Tue, May 29, 2007 at 1:33:49 PM
Display Phase I & Phase II Room Names Together
Fri, Jan 11, 2013 at 2:53:39 PM
Room names not showing up on different phases
Wed, Apr 25, 2012 at 10:47:08 AM
room tags and room spaces
Thu, Mar 27, 2008 at 9:03:52 AM
Page generation time: 1.7150
