80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Change color on joist
Mon, Mar 18, 2013 at 7:38:23 AM | Change color on joist
emmaanimonhus
Hello!
I have a wall structure (that i see in a section) built upp with structural framing, and I have defined different strucural usage for example joist and horisontal brasing. Now I wuld like to change color ony on the joist.
How can I do that?
Mon, Mar 18, 2013 at 3:01:51 PM | Change color on joist
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
One way is to edit the joist family(s) and make each family (or type) have a different 'material'. Then apply a color to that material either in the family or in the project depending on how you would prefer to control it.
Completely do-able.
Tue, Mar 19, 2013 at 1:46:29 AM | Change color on joist
emmaanimonhus
Thank you for you´re tip. but i would like to change color only in the view I´m standing.
I have tried to change it in visibility/grafics for my elevation but I can only change color on everything that is under the category structural framing, when i try to change color only on the joist nothing happens...
Change length of joist
Sun, Mar 15, 2009 at 3:22:24 AM
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
Joist Seats on sloped joists
Wed, Oct 24, 2012 at 1:27:46 PM
13
help with my 2.5K joist. got a file attached if someone could help
Thu, Jun 5, 2008 at 9:02:19 AM
Joist sitting on Sloped beams
Wed, May 28, 2008 at 8:09:37 PM
Page generation time: 0.6229
