64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> show Vapor Barrier below the foundation slab
Fri, Mar 15, 2013 at 10:55:08 AM | show Vapor Barrier below the foundation slab
Anoop
Please share your ideas about showing vapor barrier below slab and grade beam in sections.
I have tried to add membrane layer for the slab but then a finish layer needs to be added below it with thickness and revit doesnt show membrane layer in section.
Thanks
Fri, Mar 15, 2013 at 10:57:00 AM | show Vapor Barrier below the foundation slab
Anoop
I am Using revit 2013
Fri, Mar 15, 2013 at 11:12:18 AM | show Vapor Barrier below the foundation slab
We don't model this layer at all.  We use the traditional method of showing it - add a detail line ... sometimes a dashed line pulled off the face so it can be seen and noted.
Fri, Mar 15, 2013 at 11:24:09 AM | show Vapor Barrier below the foundation slab
Anoop
Thanks
so that means i have add detail lines in all the sections ?
Fri, Mar 15, 2013 at 12:00:21 PM | show Vapor Barrier below the foundation slab
jonezy
depends on what scale your sections are at, 1/50 we dont show it as its only ga section, at 1/20 1/10 1/5 yes but as a detail line offset from the surface
how do you show vapor/air barrier and membranes?
Wed, Jun 10, 2015 at 2:59:28 PM
Footing joins to gravel, not slab
Fri, Nov 6, 2009 at 6:07:21 PM
Slab Foundation Questions
Fri, Mar 7, 2008 at 10:56:29 AM
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:09 AM
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:02 AM
Page generation time: 0.5717
