Forums >> Revit Building >> Technical Support >> Add-ins, Add-ons, Plug-ins
I am starting to toy with a few add-ins for Revit now and I was curious to see what ones other people use on a daily basis, can't do without or just help their overall workflow. I've done a google search for add-ins and I know there are a lot out there but looking I want to know what other people think!
DoorTypeMarks (my own app that globally renumbers doors to corrisponding rooms)
KCL CADalog
DigiPara Elevator Architect
batchprint
collada exporter
WindowsLayout
Almost nobody in my office uses any add-ins except for me and that is not very often.
Used KCL - once
Used Elevator architect - once or twice (A pain to modify after placement - especially if not installed on your system)
Used a CAD locator - name escapes me and I seem not to have it in 12 or 13 - This one helped several times.
Had a renumber one which I used once or twice - I don't see that now either.
I have seen a couple door/room renumbering and grid renumbering ones that I could have used a time or 2 but all the ones I found were expensive and I just don't see spending $200 for using it a couple times a year if eevn that much.
KCL CADalog
batchprint
collada exporter
WindowsLayout
Collda Exporter, i don't really consider this an add-in. it's not for use in Revit. But to export your Revit file for use in another program. But that's just my thinking, no biggie
Edited on: Fri, Mar 15, 2013 at 9:55:14 AM
I use Xrev for publishing PDF/DWG. Parameter Jerk for adding shared parameters to families. Component Commander for the project browser search. I have Zoom to Awesome installed, but I keep forgetting about it.
I also have ArchiSpeak Up!, but that's just to amuse myself.
i'll share my door number app for free when 2014 is released, its very user friendy and can either work by door selected or entire protects plus it adds alphabetical suffixes to the door numbers. for example if you have ROOM A100 with 4 doors it will number the doors A100A, A100B, A100C and A100D. I've thought about adding more customizable features for it but haven't decided yet.
alabaster that would be awesome thanks!
0 Posts No Rating |
hi all
how import in revit cable tray support
Revit Plug-Ins |
Sun, Dec 30, 2007 at 3:25:05 PM
Revit Architecture 2015 Add-ins |
Tue, Aug 26, 2014 at 9:06:20 AM
Roombook Add-ins |
Tue, Oct 1, 2013 at 2:16:53 PM
Revit Add-Ins & Extensions |
Wed, Mar 2, 2011 at 4:39:17 PM
Plug-ins? |
Fri, May 8, 2015 at 8:03:36 AM
13
Members: | 2097811 | Objects: | 23164 | Forum Posts: | 152288 | Job Listings: | 3 |
