98 Users Online (97 Members):
Forums >> Revit Building >> Technical Support >> Problem with mass
12 Posts No Rating |
Hi,
I use Revit 8. I creat a mass with Extrusion. Its a ellipse form and now i wanna wall for it. How much i tried to get wall by using "wall by face " and then "pick faces" was unsuccessful. I got roof and floor but not walls.
Have another question too and it's about down loading of doors, windows... that most of time i get masseage that u use Revit 8 and this component is for higher version. Is there anywhere that i can get different component for Revit 8.
I asked the same question befor, i hope somebody can help me this time.
Thank you very much for your help
Many Thanks
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
nOT SURE HOW YOU ARE DOING IT BUT i CAN PICK WALLS ON MY ELIPSE MASS. I AM USING 8.1 AND KNOW THAT ELIPSE TOOLS ARE BETTER...
UPGRADE YOUR REVIT TO 8.1 AND THAT WILL SOLVE YOUR PROBLEMS WITH DOWNLOADING FAMILIES AS WELL
AS A REVIT USER YOU SHOULD HAVE THE LATEST VERSION...
HTH
I use the Revit 8 which is one my school's camputer so i can't upgrade it, have no idea when they wanna do it.
Problem in working with mass |
Thu, Mar 18, 2010 at 3:59:29 PM
Problem with a floor slab with Mass |
Fri, Apr 25, 2014 at 12:38:46 PM
Mass, radial wall by face, opening(void) problem! |
Mon, Nov 11, 2013 at 12:51:10 PM
Problem with loading mass with pattern in a Project |
Tue, Jul 7, 2015 at 9:30:03 AM
Cutting a section through a mass |
Sat, May 16, 2020 at 4:21:54 AM
Members: | 2017134 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
