71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> MAKING DEMOLISHED OBJECTS TRANSPARENT
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
Hi all;
Could anybody explain how to change the material of demolished walls to transparent?
I assigned a new material in Graphic Overrides for Demolished phase, but don't know how to make it transparent in PLANS and SECTIONS without usung filters and view templates.
Please help!
![dgcad Avatar](user_avatar/6183.jpg)
![3.5 Stars: 36 Votes](/images/stars_3.5.gif) |
You can adjust the Transparency of the material (demo) for 'shaded' views. Not sure about hidden line however.
Thank you for your reply. It woulbd be good tho know how to change transparensy for shaded views too (when I change the transparency value for the colour, it does not work),
but the main thing is - to make them transparent for HIDDEN LINE views.
Again, thank you very much for the image. One image worths 100 words.
However, is 20 a Transparency value? I think it is an Opacity value. If transparency is 100%, the object is completely transparent. Correct?
"However, is 20 a Transparency value? I think it is an Opacity value. If transparency is 100%, the object is completely transparent. Correct?"
Did you try it to see what it does?
In plan views it does not change at all, just in 3D. They look the same with differevt values of transparency.
Making a demolished wall transparent |
Mon, Jan 24, 2022 at 6:22:30 PM
Visibility of Demolished Objects |
Sun, Apr 5, 2015 at 6:15:48 PM
Transparent Families |
Thu, Jul 15, 2010 at 8:35:26 PM
Objects not rendering transparent |
Thu, Jul 23, 2009 at 10:38:17 AM
Transparent Demolished |
Fri, Aug 25, 2006 at 3:45:35 AM
Members: | 2016954 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
