94 Users Online (92 Members):
Forums >> Revit Building >> Technical Support >> I need help for Mass from other Application
Hello, I have project that come form sketchup file, and I never use Mass in real project before,
Can somebody help me to describe a step to do when Sketchup file is imported. how to complete
mass with imported file. for mass wall & mass floor. Thank you
If I recall correctly you make an in-place mass family and insert the SKP file into it. Then use the model by face tools.
Honestly it depends on your needs, if the mass is too big, then most probably you'll have to do again revit, if not, as one of the friends said, use "by face tools". Search on: walls by face in revit, the same method is applied for roofs and floor... (if you do it from mass)
Thank, dgcad & hydyr96
Curtain System from Mass - Mullion Joins |
Fri, Dec 11, 2015 at 7:27:44 PM
Cutting a section through a mass |
Sat, May 16, 2020 at 4:21:54 AM
Help wth Mass Please ! |
Wed, Nov 25, 2009 at 2:53:24 PM
Revit Application Engineer |
Thu, Apr 10, 2008 at 5:49:53 PM
Mass not showing completely |
Thu, Oct 30, 2008 at 11:51:16 AM
12
Members: | 2022239 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
