Forums >> Revit Structure >> Technical Support >> Repeating model in place components
12 Posts No Rating |
Hi,
Does anyone know if there is a way to create model in place components and copy them around a model then change one and have them all update? Is the only way to do this creating a family? I just find it so much easier to model in place than in a family template then importing the family into the project.
Any thoughts appreciated. Thanks.
You have the "Repeat" tool in Conceptual Mass but not in "In-place", also, use a family template to create that family (like you said you have SEVERAl models (fam.) in your project).
Each in-place model is unique. If you copy one around you will find them in your browser with the original name then an added copy number: mode1, model2, model3 etc. Since they are each unique, each copy adds file size.
Learn to create regular families.
I know how to create familes but i find the lack of background elements make it harder to do so. was just wondering if there was a way to use in place models to achieve the same thing
Editing instance of Repeating Component |
Mon, Jan 13, 2014 at 12:12:26 PM
Unable to Place Components in Linked files |
Wed, Aug 10, 2011 at 3:12:00 PM
Repeating Detail Component for Metal Lath |
Tue, Apr 1, 2008 at 12:59:07 PM
Joining model in place components |
Tue, Dec 4, 2012 at 3:38:21 AM
Repeating elements? |
Wed, Sep 28, 2011 at 6:27:32 AM
Members: | 2115974 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
