128 Users Online (127 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 3D DWG as RFA too big
Wed, Mar 6, 2013 at 8:39:12 AM | 3D DWG as RFA too big
ambrozote
5 Stars: 2 Votes
Hello,
I imported a 3d dwg of a wash basin to convert it to rfa but it ends up with 23Mb. this is way too big.
I have several dwg I need to convert to rfa.
Is there a better way to trim down the file size?
many thanks
Revit Architecture 2013
ArchiCAD 16 Win
Windows 7 Enterprise 64-bit
Wed, Mar 6, 2013 at 3:51:32 PM | 3D DWG as RFA too big
3.5 Stars: 395 Votes
You did a 3D import correct?  Not exploded so really not converted.
Wed, Mar 6, 2013 at 4:12:41 PM | 3D DWG as RFA too big
ambrozote
5 Stars: 2 Votes
I imported the CAD file. When I try to explode the imported, everything disapears.
ArchiCAD 16 Win
Wed, Mar 6, 2013 at 4:16:04 PM | 3D DWG as RFA too big
ambrozote
5 Stars: 2 Votes
Wait!
Fixed it. Was importing with the wrong units (meters instead of milimeters).
ArchiCAD 16 Win
Thu, Mar 7, 2013 at 3:51:46 AM | 3D DWG as RFA too big
4 Stars: 201 Votes
Ambrozote... One BIG RULE... before importing your CAD file into Revit, open that in CAD, explode everything, delete hatches, dimensions, texts and PURGE the file.
Thu, Mar 7, 2013 at 4:36:26 AM | 3D DWG as RFA too big
ambrozote
5 Stars: 2 Votes
You are right Typhoon.
I remembered all that. But in this case there was a single 3D Solid entity.
If you are curious, see attached file.
ArchiCAD 16 Win
Sun, Feb 2, 2014 at 1:32:44 PM | 3D DWG as RFA too big
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
you could use this external command for 3D DWG http://puntorevit.blogspot.it/2014/01/3d-dwg-to-rfa-external-command.html
Dwg to RFA and Materials.
Sun, Feb 2, 2014 at 1:40:54 PM
DWG 3D TO RFA CONVERSION?
Sun, Feb 2, 2014 at 1:37:21 PM
Multiple import dwg as multiple Family
Sun, Apr 9, 2017 at 8:38:41 AM
From .Dwg to .Rfa
Tue, Feb 24, 2009 at 1:32:24 PM
Are there any dwg /dxf files to download, all I see is *.rfa
Thu, Feb 5, 2009 at 10:12:18 AM
Page generation time: 0.3814
