62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Which material did I paint?
Tue, Mar 5, 2013 at 9:49:11 PM | Which material did I paint?
twebb
4 Stars: 1 Votes
I've painted a surface with some material.  I've forgotten what that material was.  Is there a way to determine what material has been painted?
Revit 2011
Thanks-
Wed, Mar 6, 2013 at 3:18:19 AM | Which material did I paint?
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
When you are in the command 'Remove Paint', take your cursor to that surface and make sure that surface is highlighting. You can see the used material in the Status bar or Tooltip.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Paint Material Takeoff-Walls
Mon, Aug 11, 2008 at 11:56:32 AM
"Paint" and In-Place Component Material Bug?
Thu, Apr 14, 2016 at 2:47:43 PM
WALL CUT (openings) MATERIAL
Sat, Sep 28, 2013 at 10:56:04 AM
Material tags in painted wall faces Revit 2014
Sat, Oct 15, 2016 at 1:25:08 PM
Can't Remove Paint from Stair
Tue, Aug 28, 2012 at 8:01:37 PM
Page generation time: 0.4840
