128 Users Online (126 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> NON revit mass into revit?
Fri, Jan 27, 2006 at 1:26:27 PM | NON revit mass into revit?
SRobbins
Hey guys, I have a SketchUp Wall. I want to pull the custom SketchUp wall into Revit as a wall using the Model > Create and Wall tool. This way my wall I made in SketchUp can have doors and windows put in. But for some reason when ever I try to export to DWG and pull that mass into Revit, it doesn�t let me. any ideas? Thanks Scott
Fri, Jan 27, 2006 at 2:42:28 PM | RE: NON revit mass into revit?
TomDorner
4.5 Stars: 25 Votes
From E. Phillip Read � Solutions Architect Autodesk "Integrating Sketchup and Autodesk Revit" guide In order for Revit to understand the exported geometry as a Mas object, link the file into a Mass Family component. By doing this, Revit treats the geometry as a Mass, alowing the faces of the mass component to be selected and asociated to Revit host elements. Furthermore, the relationship betwen imported mas geometry is maintained if the SketchUp file is modified, exported and reloaded in the Revit project. Here�s the critical path from SketchUp to Revit: 1. Create the massing study in SketchUp. Export to DWG. 2 From Revit, select File>New>Family>Mas.rft. 3 Link the exported DWG file into the family. 4 Save family. 5 Load the Mas Family into the Revit project and place the component. 6.Use Wal/Roof/Curtain System by face command to select the faces of the Mas component.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Mon, Jan 30, 2006 at 12:46:33 PM | RE: NON revit mass into revit?
SRobbins
You know what stinks about that? :-( When I place the building as a wall, the windows and doors want to center themselves in he middle of the building. unfortunatally the whole building gets counted as a wall and not just the 3D geometry that makes up the SketchUp walls. Anyone know a solution to this?
Cutting a section through a mass
Sat, May 16, 2020 at 4:21:55 AM
Revit 2008 mass visablity problems
Wed, Jul 25, 2007 at 8:19:08 PM
Revit 2017 In Place Mass
Tue, Jul 12, 2016 at 3:06:49 PM
Autocad 2011 Solid To Revit 2011 Mass floor error
Mon, Feb 28, 2011 at 7:20:11 AM
Export Mass from Revit 2009 to 3ds Max 2009
Tue, Feb 16, 2010 at 9:13:54 AM
Page generation time: 1.8163
