Forums >> Revit Structure >> Technical Support >> Searching for the instances of a family within a project
6 Posts No Rating |
I am currently troubleshooting some old files. Is there any way to search for the occurrence of a family in a file. I know how to select all instances of a family and see how many occur. Is there a way to locate these instances?
Thank you in advance
I do it from a 3D view.
6 Posts No Rating |
Thanks for the response, actually the families are detail families in the drafting views.
I wish you had been clear initially.
No way that I know of to find these items short of opening each view.
But here is a "bubble sort" option...
- Open a new copy of the program
- Make sur you know how many instances you have
- Delete 1/2 the views then see how many instances you still have ... hopefully all of them
- If say 1 drops off, you can search for one in the original views you deleted by bringing them back and deleting 1/2 of those.
- Delete 1/2 of remaining and look at how many
As you can see, this can be a fairly fast way of finding the instances.
6 Posts No Rating |
Thank you very much. That is a creative way to find the instances.
6 Posts No Rating |
Can a Schedule be created listing the family and the views they are in?
I checked for that first and did not see a way.
6 Posts No Rating |
Thank you for your help. Find location of instance should be on the Revit wish list. If anyone finds another way, I am all ears.
6 Posts No Rating |
The solution I came up with is this:
1. Select all instances
2. On the manage tool bar "show ids of selection"
3. Copy and paste into notepad
4. Copy a single ID from notepad
5. On the manage tool bar "select by Id"
6. Show
That's a solution that helps me find the orphaned family instances that exist in my project.
