Forums >> Revit Building >> Technical Support >> wall sweep to stairs
![5 Stars: 2 Votes](/images/stars_5.gif) |
Hello,
Can anyone tell me the most correct/efficient way to prolong a wall sweep onto a staircase (please see jpg attached)?
Many thanks.
REVIT Architecture 2013
Revit Architecture 2013
ArchiCAD 16 Win
Windows 7 Enterprise 64-bit |
Sorry but your question is not clear.
Is it an in-place sweep or a wall defined sweep?
Not sure how good your image does. I assume you mean the base at the landing? What do you want it to do?
The wall sweep (brown, to the left) is a wall defined sweep.
I need to stop it once the stairs start, and I was wondering on how could I create an object that would follow the wall sweep along the stairs. I have drawn it in black, roughly.
ArchiCAD 16 Win
Do you know that you can define a stringer for your stairs? See attached.
Look at the stair samples on the on-line library. http://revit.autodesk.com/library/html/index.html
I have tried to edit the stairs and add stringers but nothing seems to happen....
ArchiCAD 16 Win
Open the file I pointed to! You can copy that and load it into your project. Then look at the settings!
the link does not point to a particular object.
ArchiCAD 16 Win
" stair samples on the on-line library" <<<<< SAMPLES - CLEAR?
Eureka!
The problem was that I was trying to create stringers on a monolithic stair. Can't do that.
Many thanks for your help and time.
ArchiCAD 16 Win
angles wall sweep for a baseboard |
Mon, Dec 2, 2019 at 3:52:26 PM
Sweep Path for Stairs |
Fri, Feb 1, 2019 at 6:39:48 PM
Wall sweep won't trim |
Tue, Apr 25, 2017 at 2:07:17 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ] |
Sun, Dec 7, 2008 at 3:51:44 PM
19
How to Load a Wall sweep type |
Mon, Jun 9, 2008 at 12:42:29 PM
